Date/Time: Sat, 17 Jan 2026 00:22:38 +0000
Minor Bug in TAL
View Count: 137
| [2025-12-02 03:07:44] |
| User925540 - Posts: 142 |
When filtering by symbol in the trade activity log, the list of symbols available to choose from isn't the full list of all symbols that is there in the log. My guess is that there is some sort of limit so at a certain point (as the list grows) not all the symbols are going to be shown as options to select from? Impact is minor but a bug nonetheless. |
| [2025-12-02 03:47:16] |
| Sierra_Chart Engineering - Posts: 22419 |
This is definitely not a design flaw. You are correct, that there is a limit to the number of symbols in the list since it is too time-consuming to determine all of them from the files. Just simply manually enter the symbol that you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-02 03:47:36
| [2025-12-05 23:20:19] |
Maybe you are referring to the filtering in the TAL Display Settings . That actually works hand the list is complete and you do get the option to even insert a value manually.I was referring to the > Quick > Symbol menu.Anyway, the TAL Display settings works well so it's just a minor glitch, no need to be bothered by it. Thanks. |
