Date/Time: Wed, 25 Nov 2026 21:35:58 +0000
Detach chartbook window
View Count: 397
[2025-12-01 19:03:51]
Piotr Grzegorzek - Posts: 36
Could you add a function to "detach chartbook window" (the same as "detach chart window" works) so it could be moved to another screen and that it would be "always visible" even if I switch to another chartbook on another monitor.
I have one chartbook for CL, GC, YM, 6E each (with 1m, 5m, 15m, 240m, 1d charts) and one more with all 1m charts for CL, YM, GC, 6E. I want this all 1m chartbook to always be visible on the left screen and I need the rest of the chartbooks to be visible on the middle screen to be able to switch between the chartbooks for CL, GC, YM, 6E.
I tried doing this with new instance but then when I draw a line on YM_1m chart on the main instance it does not appear to the sub instance chart.
[2025-12-01 19:50:56]
This has been long asked for, and with the MDI window changes described at the top of this board, we will have the ability to do this but we do not know when it would be implemented.
Date Time Of Last Edit: 2025-12-01 19:51:12
