Date/Time: Tue, 17 Nov 2026 18:08:53 +0000
Market data not showing
View Count: 354
[2025-12-01 17:02:38]
ldepadey - Posts: 73
hI is there a setting i need to enable market data, for example if 50 contracts is flashed on es, it doesn't seem to be showing on DOM
[2025-12-01 18:31:32]
John - SC Support - Posts: 48555
If you are specifically referring to Market Depth data, then refer to the following:
Global Trade Settings Windows: Troubleshooting Market Depth Data Not Displaying in Chart/Trade DOM Columns
But you also need to look at where you are getting your data from. You are not setup to get any real-time data from our Denali Exchange Data Feed, but if you are getting our Delayed Streaming Data for the CME Group or EUREX, then you will have access to the Market Depth data.
