Date/Time: Wed, 25 Nov 2026 21:36:03 +0000
Ver.2814--->2817 fyi SC
View Count: 498
[2025-12-01 15:55:56]
blt - Posts: 233
Good morning SC TEAM
Here are first takes on newest Ver.2817 (to remind you-am running 1+6 instances/ 7 monitors)
1.When you want to open Chartbook in sub instance pop-up always open on main instance monitor even if I move pop-up to sub instance monitor to try again-still goes back to main monitor/instance (annoying; that functionality was working in Ver.2814)
2.Now comes tricky one:
In main instance I have linked/period two charts (trades and Numbers Bar charts)
When I change period by clicking on trades chart it takes long for Numbers Bar to open just to stall after couple of sec; then working a bit and stalls again
If I change period by clicking on Numbers Bar chart it changes promptly although stalls a bit later totally like right now (when you click on chart it moves again)
3.When you want to reposition any MDI window it is VERY sluggish (trying to drag it)
4.Cumulative Delta (having that reading present everywhere in my chartbooks) is widely off
5.Title bars are very pleasant and their adjustment is a breeze
For these I am going back to Ver.2814 (that is perfect for me till the day I die)
Also my Update Interval was 50ms in Ver. 2814 even increasing it to 100ms for Ver. 2817-still very sluggish/stalling !!!
Hopefully this could help
As I stated in post title "fyi" do not feel pressured to respond to these takes; I am confident that all will work to perfection in some time
Enjoy December and all the best
[2025-12-01 16:42:25]
blt - Posts: 233
Now...I have the same problems in Ver. 2814 !!!
This is now getting a bit tricky to handle
[2025-12-01 17:03:05]
blt - Posts: 233
Now...I am back to Ver. 2813...everything works perfect !!! (minus uncontrollable height of Windows Title bars-feel free to rant)
[2025-12-01 23:08:57]
Post #1 is not making sense to us.
1. We do not know what you are referring to at all.
2. We do not understand this. This is not making sense. We do not understand how clicking on one chart causes the timeframe per bar of another chart to change.
3. It is what it is.
4. This cannot be related to a particular version.
We are not going to be spending any time on this thread other than looking at 3.
We do not see how any of this is related to the new version. Other than 3 and we will see what can be done.
Date Time Of Last Edit: 2025-12-01 23:09:53
[2025-12-02 01:03:07]
blt - Posts: 233
Allow me to try again:
I run 7 instances on 7 monitors
I want to open Chartbook in instance let's say 5 (on 5th monitor)-->clicking on OPEN CHARTBOOK tab pop-up with many others CHARTBOOK available to be opened will pop-up on monitor 1 where main instance is located
Then I select one of many CHARTBOOKs
If I click and drag that pop-up from main instance (monitor 1) to monitor 5 where I want to see that pop-up functioning and want to open/select another CHARTBOOK pop-up shows again on monitor 1; etc...
Ver. 2813 does NOT do that !!!
When I click on tab to open CHARTBOOK by selecting one CB of many on any of 7 monitors pop-up is ON THAT MONITOR !!!
Please do not tell me you do not get this !!!
Also 1.; 2. had purpose to illustrate "sluggishness and stalling" that has been caused by implementing MDI charm to platform
In the end just to elaborate myself a bit clearly:
SIERRA CHART is my 4th platform and probably my last one!!!
I NEVER !!! was WRONG about ANY TECHNICAL ISSUE that occurred in previous three I used...NEVER !!
Meaning: If I say that something is wrong with SIERRA CHART---> then SIERRA CHART is having problem not my trading marvel or anything around it involved
If you can't get what I meant because of my poor English sorry for that
Now try to fix that MDI...it is not working properly
Enjoy smile let's make it right
Leonardo
[2025-12-02 20:54:53]
1. Now we understand the problem and we know why this has happened. There is a background technical reason for this that was not apparent to us until now and we will go through and fix all of these cases.
3. This is already resolved.
