Date/Time: Wed, 25 Nov 2026 21:36:01 +0000
v2816 Pre-Release Issue?
View Count: 360
| [2025-11-30 20:26:20] |
| TriStar Trading - Posts: 201 |
Just updated to 2816. Min, Res, & Cls are alpha and not far right on control bar. Was this intended? See attached. Thanks! Mike
| [2025-11-30 22:26:52] |
| Sierra_Chart Engineering - Posts: 25483 |
We need to prepare documentation for how to configure those commands. The settings are in Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings. You can configure, the menu command names and also the separator. Child window controls are implemented as menu commands. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
