Date/Time: Wed, 25 Nov 2026 21:35:51 +0000
How to Reposition Trade Window Stuck Off-Screen (Reset Windows Not Working)
View Count: 974
[2025-11-30 01:35:27]
User966246 - Posts: 15
My Trade Window has become stuck off-screen in a strange position, and I’m unable to move it back. The top portion of the window is hidden above the display edge, so I can’t drag it or access its title bar. I’m not sure how it ended up there. I've already tried in Sierra Window → Reset Windows, but it does not reset the Trade Window’s position. I’ve also tried different things in Windows with screens, but nothing helped.
Is there another way to force the Trade Window back onto the main screen or manually reset its location? Some file, config somewhere?
(See attached screenshot for reference.)
Thank you.
image2025-11-29 20 26 54.jpg / V - Attached On 2025-11-30 01:28:27 UTC - Size: 566.5 KB - 193 views
[2025-11-30 04:28:04]
For this, you need to go to the chart, that Trade Window is for and then select Chart >> Reset Child Windows.
Date Time Of Last Edit: 2025-11-30 04:28:34
