Date/Time: Wed, 25 Nov 2026 21:35:55 +0000
[Programming Help] - Custom Volume Profile
View Count: 358
| [2025-11-29 17:29:08] |
| User213910 - Posts: 28 |
Hi Sierrachart Team. Is it possible in ACSIL to draw a volume-profile-style display - meaning the horizontal bars, but using custom values instead of actual volume data (for example, values that are calculated or imported)? Thanks for your help. |
| [2025-11-29 19:22:42] |
| User431178 - Posts: 910 |
Is it possible in ACSIL to draw a volume-profile-style display It's possible. You can use s_UseTool, GDI or sc.Graphics for the drawing, depending on what you require. |
