Date/Time: Wed, 25 Nov 2026 21:36:10 +0000
Ubable to Connect
View Count: 356
| [2025-11-28 12:54:34] |
| User563409 - Posts: 2 |
Good morning/afternoon, I am unable to connect to the service ´connect event error. windows error code 10060 i have attached the screenshot this is the first time this has continued to do this please advise thanks |
| [2025-11-28 13:32:43] |
| Sierra_Chart Engineering - Posts: 25483 |
You should be able to connect to Sierra Chart now. If not update Sierra Chart to the latest version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
