Date/Time: Wed, 25 Nov 2026 21:36:08 +0000
TPO period opening - two letters highlighted in the first period
View Count: 355
| [2025-11-28 04:32:26] |
| Orangutan - Posts: 9 |
Hey Team, I noticed that for the TPO profile of the last trading day, if you look at the first period (A period), there are two separate letters that are highlighted. I have enabled only highlighting the opening price (colored blue in the screenshot). You will notice that there is another price/letter that is highlighted as well (in yellow), which does not make sense. This is for the symbol "HOOD" , last trading day (11/26). |
| [2025-12-01 07:29:14] |
| Sierra_Chart Engineering - Posts: 25483 |
Check the color settings: Time Price Opportunity (TPO) Profile Charts: TPO Chart Color and Width Settings And find out what the yellow color is for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-01 07:29:37
