Date/Time: Wed, 25 Nov 2026 21:36:05 +0000
Global graphics setting not copying to chart
View Count: 407
| [2025-11-28 04:05:52] |
| User273277 - Posts: 145 |
Quick thing I just noticed. In Global Settings, Graphics Settings - Global. I set the Trade DOM Grid to Color Black, Line Style Solid. Select a Trade DOM window. Select Chart, Graphics Settings - Chart. In Colors and Widths, Deselect Use Global, click Apply. Click copy from Global and click Apply. the window goes away, so go back into the Graphics Settings - Chart. The Trade DOM Grid setting is set to Color Grey, and Line Style Dot. The expected result is for the Trade DOM Grid setting to be copied from Global. |
| [2025-11-28 22:08:25] |
| Sierra_Chart Engineering - Posts: 25483 |
We will check on this.
| [2025-12-01 02:06:53] |
This will be solved in the next release. Required special handling since some of the Trade DOM Graphics Settings are separate variables.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-01 02:07:00
