Date/Time: Wed, 25 Nov 2026 21:36:03 +0000
Multiple Sierra charts on same PC
View Count: 405
[2025-11-28 00:52:21]
User449867 - Posts: 12
HI
I am running 2 instances of SC on the same PC the 2nd being a copy of the 1st
I am using the 1st for paper trading through Rithmic - this version is also running all my Charts Doms etc and is on it own drive
The 2nd SC I am using for 2x DOMs through my Rithmic live account trading in SC's sim mode
Is it correct that the E:\ drive which is the original version has Chart image and Text editor from D:\ drive?
Where the copy is running everything from D:\ drive
Hope this makes sense
Private File
[2025-11-28 23:19:46]
This is not a problem but what we recommend you do is just clear each of those paths and they will be set back to default which will then match the folder associated with the instance.
