Date/Time: Wed, 25 Nov 2026 21:36:04 +0000
CQG WEB API
View Count: 609
| [2025-11-27 13:28:11] |
| User642012 - Posts: 63 |
HI I AM CURRENTLY CONNECTED TO CQG DATA FEED THROUGH CQG WEB API WITH AMP FUTURES. IF I SWITCH TO ANOTHER FCM WITH CQG DOES IT REQUIRE THE FCM TO ENABLE CQG WEB API FEATURES ? AND WHAT PTOTOCOL NEEDED, SD THE CQG DOCUMENTATION METIONED privateLabel = 'WebAPITest' clientAppId = 'WebAPITest' AND WITH MY CURRENT CQG CREDITIAL IT DIDNOT WORK AND I HAVE CHECK SIERRA CHART SETTING THERE ARE NO SUCH FIELD REQUIRED PLEASE ADVISE |
| [2025-11-27 16:06:20] |
| Sierra_Chart Engineering - Posts: 25483 |
For what is required, refer to: CQG Trading Platform Service: CQG Account Requirements Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
