Date/Time: Wed, 25 Nov 2026 21:36:12 +0000
Flatten position at set time
View Count: 394
[2025-11-27 09:23:04]
User826949 - Posts: 22
I have a question regarding this feature. I set this under the Global Profit/Loss Management. I set it to close positions at 16:55:00. 5 minutes before the close. It works fine, except in a few days it didn't close the position. (I was trying it in Demo) So I would like to understand what conditions must be met for this to work. For example what happens if the computer goes to sleep? Anything else I should know for this work?
Thank you.
[2025-11-27 16:42:56]
TonyCipriani - Posts: 155
That's local based, meaning you have to be connected and your computer has to be on. They did say that they could be looking into bringing back Global profit/loss management to have it server based though, so we'll see.
Just make sure your computer is on. You can disable your PC to never go to sleep.
[2025-11-27 16:54:10]
Thank you. I figured that the computer going to sleep is the problem. I hope it goes server side; I will be using this regularly. Thank you again for your response.
