Date/Time: Wed, 25 Nov 2026 21:24:00 +0000
VBP & Data Limiting
View Count: 371
| [2025-11-26 20:21:23] |
| User246578 - Posts: 87 |
Hi there, Is it possible using same DOM to customize/adjust "Data Limiting filter" for each VBP differently? Example: 1. DOM has 2 VBP's placed one next to each other; 2. VBP (ID:1) shows "Total Volume" with Data Limiting set to => 499; 3. VBP (ID:2) shows "Ask Volume - Bid Volume" with Data Limiting set to => 0 Thank you, |
| [2025-11-26 20:22:20] |
You can have two Volume by Price profiles on a Trading DOM and have different Data Limiting set on each of them. Have you tried this and had a problem? If so, what exactly is the issue? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-26 20:39:03] |
How can you have different Data Limiting set on each of the DOM's VBP??? There is only one Data Limiting for a DOM. Would you please let me know how to do it? Thank you |
| [2025-11-26 21:02:21] |
Sorry, we thought you were referring to the Input for the "Volume by Price" profile of "Volume Text Threshold". There is not a way to do what you are wanting. The Volume Filtering you are referencing applies to an entire chart (or Trading DOM). And there is not a way to overlay a Volume by Price profile. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-26 21:20:01] |
Ok, thx
