Date/Time: Wed, 25 Nov 2026 21:24:14 +0000
Create 5 day compostie volume profile
View Count: 372
| [2025-11-26 11:09:31] |
| User560704 - Posts: 17 |
hi, I am trying to create a volume profile, I have added it to the right, i want to use a fixed time period of 5 days, I believe i have done this, however it gives me a look back further than days, something is not correct, haven't been able to work this out, youtube tutorials also not able to reflect this. as you will see this composite goes higher than the last 5 days, it actually reflects all the way up to ES all time highs, no setting from what i can see is configured for this.. pic attached thanks |
| [2025-11-26 14:54:15] |
We can not see the time scale at the bottom in order to understand how the bars relate to the profile. From what little bit we can see, it looks like there are two days of data showing. We would need to see the entire 5 days of data for which the profile is associated in order to see the relationship between these two. And we need to seee the time scale to know where the data lines up. Also, we need to know what the "Volume Graph Period Type" is set to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
