Date/Time: Wed, 25 Nov 2026 21:24:20 +0000
VBP bars outline when zoom out
View Count: 357
| [2025-11-25 09:18:30] |
| User981449 - Posts: 52 |
Hi Support, Is it possible to make the outline disappear when the chart is zoomed out, or simply have the outline use the same color as the delta bars? Unfortunately, when the chart is zoomed out and an outline is present, the delta bars appear as a single solid color. when zoomed in it's all fine. thank you |
| [2025-11-25 15:19:29] |
You can turn off the use of the Outline for the Bid/Ask coloring by the following Input: Volume By Price Study: Draw Outline When Coloring Bid Volume And Ask Volume And you can change the color of the outline via the following subgraphs: Volume By Price Study: Volume Bars Outline and Fill Colors (SG8) Volume By Price Study: Evening Session Volume Bars Outline and Fill Colors (SG11) In the end, when you zoom out, the best option is to adjust the "Ticks per Volume Bar" in order to be able to view the data better. Refer to the following: Volume By Price Study: Ticks Per Volume Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
