Date/Time: Wed, 25 Nov 2026 21:24:20 +0000
Up-Day Candle Rendering as Down-Day
View Count: 359
[2025-11-24 05:30:21]
JL2711 - Posts: 6
Hi - I'm charting ES future contracts (please see the screenshot link below). On 11/7/25 the price closed higher, but the chart is displaying the candle in a down-day color. I didn't notice any other candles doing this. I played around with session times, but that didn't fix it.
https://www.sierrachart.com/image.php?Image=1763961510200.png
imageScreenshot 2025-11-23 205447.png / V - Attached On 2025-11-24 05:10:02 UTC - Size: 71.68 KB - 161 views
[2025-11-24 05:34:48]
Check this setting:
Graphics Settings: Up/Down Coloring for OHLC Bars Based on Previous and Current Close
The body of a candlestick bar is always colored according to the relationship between the Open price and the Close price within the same bar. The option above, can be used to color, the high to low portion of the candlestick bar according to the relationship between the close and previous close.
Date Time Of Last Edit: 2025-11-24 05:59:32
