Date/Time: Wed, 25 Nov 2026 21:24:19 +0000
Draw Volume Profile tool selection color
View Count: 421
| [2025-11-23 20:27:14] |
| User937068 - Posts: 45 |
Hi Not sure if this is from my graphical settings or not. I have the Draw Volume Profile on my chart and if i select it i see the period for which is drawn. However this is not visible once it is deselected. Is there an option to have the selection displayed permanently? Attached screenshots. |
| Attachment Deleted. |
| [2025-11-24 16:54:28] |
You need to enable the following option for what you want to see: Volume By Price Study: Draw Profile Outline Enclosing Bars Then make sure you save the Study Collection that you use for your Drawn Volume Profile so that the option is enabled when you draw it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-24 19:45:39] |
Thank you!
