Date/Time: Wed, 25 Nov 2026 21:24:19 +0000
collaboration with other trades when building auto trading system
View Count: 408
[2025-11-23 14:27:37]
stiasny - Posts: 25
Hi, I am a developer of auto trading system. I would like to know your advice on how to best collaborate with two traders, so they can review the fills and suggest improvements to the system. What are my options?
Thank you.
[2025-11-23 21:27:10]
For this, you will want to use the Trade Activity Log and all of the various tabs of information:
Trade Activity Log
The data can be saved to files.
Date Time Of Last Edit: 2025-11-23 21:37:12
[2025-11-25 22:35:22]
stiasny - Posts: 25
Thanks, but what we need is that they are able to see the entries on the chart and whether they were profitable or not. I have prepared a study which overlays the 1 min entry arrows to higher timeframe charts, so that way they can try and align and filter out the bad trades based on higher timeframe bias. Only with arrow they cannot really see if the trade was successful. but with order fills they could. But if i share a chartbook with them, they dont see those fills, since it seems that order fills are tied to my sierra account
Any neet way of doing that? Or would creating a separate Sierra account which we would use for this be needed?
[2025-11-25 22:56:41]
We are not quite certain of what you are trying to do, but you can export the Trade Activity Log and then that information can be imported into another system and those order fills displayed on the chart. The specific Trade Account utilized will have to be selected properly to display the fills for a chart. Refer to the following:
Trade Activity Log: Importing and Exporting Data
[2025-11-25 23:17:50]
stiasny - Posts: 25
Ok thanks we will try with that trading activity export import. So my friends need to see the trades and whether they were profitable. By showing order fills of my back test in the replay mode is the easiest since they can also display them over all higher timeframes charts if needed. And see some correlation for improving the results.
Cheers
