Date/Time: Wed, 25 Nov 2026 21:24:17 +0000
[Programming Help] - Sierra Chart DTC Protocol C# Demo/Header Files Contribution
View Count: 590
| [2025-11-23 01:36:14] |
| EquitySimp - Posts: 4 |
Hey Guys, I tried contacting your DTC@dtcprotocol.org email but it seems to be out of service. I Love the work you've done with the DTC Protocol and as a way of giving back I've put in some boilerplate C# code for DTC Cxn and order updates from Sierra Chart using .NET Desktop Applications (You're more than welcome to put it on your DTC Sierra Chart docs with those C++ headers). It basically uses a JSON comms method with no "authentication" between client and server. I used that code for a product I'm launching soon called SierraStep (Allows people to use SierraChart + Denali to trade Topstep Accounts using Topstep's API, basically a 1-1 order router and manager that just lets you use "Sim1" on Sierra to trade any TS account). I know your support boards get a million questions about prop firms, so hopefully this can serve as another option to the rithmic nightmare, should you choose to mention it. Cheers and keep up the amazing work with DTC and Sierra! Joseph https://www.sierrastep.com/ |
| Attachment Deleted. |
