Date/Time: Wed, 25 Nov 2026 21:24:21 +0000
Feature Request: Daily P/L divisor
View Count: 422
[2025-11-22 00:30:40]
chili - Posts: 15
Since the Ignore Quantity feature only works for open P/L, and not for Daily P/L, would it be possible to add a simple parameter that could be set to apply a divisor to the Daily P/L value?
For example, if the Daily P/L was 40 ticks total, and your default trade size is 2 contracts, you could set the parameter to 2 and it would divide the Daily P/L of 40 ticks by 2 so that it instead displays 20 ticks on the chart/DOM. It would act as a sort of simple workaround to allow the user to display the P/L in ticks/points on a per contract basis, which would be very helpful.
[2025-11-24 15:09:19]
We have noted this as a Feature Request. We can not say when we would get to any particular request.
