Date/Time: Wed, 25 Nov 2026 21:24:18 +0000
Data limiting
View Count: 648
| [2025-11-21 17:05:34] |
| User581066 - Posts: 37 |
Hi, I put the data limiting to date range. Range start at 2025-03-17. Everytime i change it to 2025-10-17 to load less datas and save it it doesnt change and it still range from 2025-03-17. How can i save the range ? |
Private File |
| [2025-11-21 19:20:16] |
You are changing the wrong Date Range. The one you are changing is the "Date Range in File From". You need to change the ones below that say "Date Range From" and "Date Range To". Refer to the following: Chart Settings: Load Data Limiting Method: Date Range >> Date Range From / To (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Date Range menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
