Date/Time: Fri, 25 Sep 2026 15:56:40 +0000
Prevent Removal Of Study Via Password
View Count: 522
[2025-11-21 16:23:54]
jsandlan - Posts: 99
Is it possible or could it be possible through a new feature to create a study that cannot be removed from a chart book without first entering a password?
The reason for this is that I have a custom study that limits the number of trades I place per session and I do not want to be able to remove that study.
It would be incredible to be able to prevent that study from being removed unless a password was entered.
[2025-11-21 16:30:14]
John - SC Support - Posts: 48013
This is not currently available.
We have noted this as a Feature Request. We can not say when we would get to any particular request.
[2025-12-09 15:03:44]
Sierra_Chart Engineering - Posts: 24971
This is not something that we would add.
[2025-12-09 19:06:31]
One of the reasons that discretionary / independent trading is so difficult is that you do not have a risk manager to step in when you should not break your rules but inevitably override your best judgement.
Allowing a password for removal of a study, would allow a user the protection a risk manager provides so that when emotions are high you have no way to break your own rules.
The password could only be known by a partner so you have no easy way to break your own rules.
An alternative solution to this problem would be a way to prevent in-platform risk management rules from being changed without a password. Is the rationale here compelling enough to create the suggested functionality? If not, what about being able to password lock in-platform risk management rules.
[2026-06-25 16:25:25]
aseef - Posts: 55
I agree with jsandlan that atleast a password protection on a study is simple to do to protect it from deleting. Can you please provide this feature?
[2026-06-26 13:37:10]
Marmany - Posts: 319
jsandlan & aseef,
For info I achieve what you are after by having the study you do not want removing set a persistant integer to a non zero value eg 10. Then in your trade placing study:
StudyLoaded = sc.GetPersistentIntFromChartStudy(1,2,0);
if(StudyLoaded != 10)
sc.PlaySound(13,"Bar Timer missing", 1);
or add code to flatten all
