Date/Time: Wed, 25 Nov 2026 21:23:55 +0000
DTC JSON WebSocket: Successful Logon, but Silent Failure on Market Data Request (Rithmic)
View Count: 527
[2025-11-21 01:59:28]
nach1321 - Posts: 13
I am coding a local web client using the DTC Protocol (WebSocket / JSON Encoding) to read Market Data and Depth to try some visualizations.
I am able to successfully Connect, Handshake, and Logon. The Heartbeats are exchanging correctly. However, when I send a Market Data Request (Type 101), the server receives the message (confirmed in the Message Log) but sends no data back.I do not receive a Market Data Reject (Type 103), nor do I receive any Market Data Snapshot (104/122) or Updates (102/113). It effectively goes silent for that specific symbol request.
Configuration:
Data Feed: Rithmic Direct (rithmic_v2.trading)
Symbol: NQZ5.CME / NQZ25 (I have tried both the SC internal format and the Rithmic raw format).
DTC Settings: Protocol v8, Encoding: JSON, TLS: Off.
Current Date in Log: 2025-11-20 (Simulated Environment Date).
The Log Output:
2025-11-20 20:50:56.152 | DTC client #87. ErosionTape. 127.0.0.1 | Received logon request.
2025-11-20 20:50:56.152 | DTC client #87. ErosionTape. 127.0.0.1 | Sent successful Logon response message to client. Username: . Result text: Connected to SC DTC Protocol server. Service=rithmic_v2.trading|SymbolSettings=rithmic_v2.trading
2025-11-20 20:50:56.213 | JSON data: {"Type":601,"RequestID":101,"Symbol":"NQZ25"}
2025-11-20 20:50:56.213 | JSON data: {"Type":101,"SymbolID":101,"Symbol":"NQZ25","RequestAction":1}
2025-11-20 20:50:58.155 | JSON data: {"Type":3,"NumDroppedMessages":0}
Is there a specific symbol format required when requesting Rithmic data via the DTC Bridge (e.g. [M]NQ vs NQZ5.CME)?
If the symbol is invalid, shouldn't I receive a Type 103 Reject message?
Does the Security Definition Request (Type 601) function when bridging to Rithmic, or should I rely solely on Type 101?
Thank you.
[2025-11-21 15:10:21]
You can not use the DTC service to get data of any kind. The exchanges do not allow this. Refer to the following:
Data and Trading Communications (DTC) Protocol Server: Restrictions
