Date/Time: Wed, 25 Nov 2026 21:24:05 +0000
Tick charts
View Count: 512
[2025-11-21 00:02:27]
User445935 - Posts: 1
Hi there. I’m looking to trade on 70 tick chart. I have tried everything to get of 1 minute and into tick chart. Would there be anything you could check on your end to see if you could help me out?
Many thanks
Conor
[2025-11-21 00:28:49]
User719512 - Posts: 548
You might like this:
Refer to the following:
Changing Chart Bars Period: Fast Changing by Keyboard
Also, try:
click your chart/select it and TYPE
70t[enter]
Also see Chart Settings (F5)
Bar Period tab
Bar Period Type
Number of Trades per Bar
...and set the Bar Period Value to 70
Date Time Of Last Edit: 2025-11-21 01:15:19
[2025-11-21 01:49:19]
blt - Posts: 233
...left click your mouse pointing anywhere at chart you want to turn into tick chart and type (keyboard) number of ticks you want followed with letter "t"...
...in your case point/click at chart and type "70t" then press enter...
[2025-11-21 15:08:54]
