Date/Time: Wed, 25 Nov 2026 21:24:21 +0000
Casndle stick Color
View Count: 383
| [2025-11-20 19:08:48] |
| Artieb60 - Posts: 14 |
Hi, I have literally spent hours trying to make my candlesticks green for up and red for down. I do what the instructions from you and the internet and cannot do it without destroying the other graphics on all my charts. To do this simple task should not be this hard. This has happened before last year. Please help me. Thank you, Art |
| [2025-11-20 19:10:04] |
We are a bit confused, as the default settings are such that you will get a Green candlestick for an Up bar and a Red candlestick for a Down bar. So there is no reason that you should have needed to change this. But, since things have probably changed along the way, we will need to take this one step at a time. The first question is whether you are wanting to have this apply to all charts or just to one specific chart? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-21 17:27:40] |
I doesn't really matter. This whole thing started because Sierra is so slow and clunky. I don't know if it is when I updated or what. I've tried all the ways to speed things up, instead of prices changing in big chunks. I've gone back to Ninja, which is working wonderfully, even though I did like my indicators and things when Sierra worked better. What a shame....
