Date/Time: Wed, 25 Nov 2026 21:24:04 +0000
Is it possible to click and display 2min time based charts?
View Count: 366
| [2025-11-20 12:05:03] |
| User293951 - Posts: 27 |
Hi! I have tried to find something on this but have failed so far. I want to be able to switch between periodicities in a specific time based chart. Keyboard shortcuts are the best choice for this. So I tried and found that Intraday bar periods of 1, 5, 10, 15 etc minutes are supported. I tried to apply custom periods, most important for me is 2min, but did not succeed. Is there a way to apply 2min periodicity without going through the conventional loop (F5, etc)? Thank you in advance. |
| [2025-11-20 15:49:21] |
Refer to the following: Changing Chart Bars Period: Fast Changing by Keyboard For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
