Date/Time: Wed, 25 Nov 2026 21:24:13 +0000
[Programming Help] - ASCIL Custom Study Calculation Order and Precedence
View Count: 426
[2025-11-19 20:43:11]
Gradient - Posts: 219
I have a study, "Study A", that works fine. I wanted to make my system more modular so I copied some functionality from Study A and pasted it into a new study, "Study B".
No changes to logic have been made.
Both Study A and Study B have a Standard Calculation Precedence.
Study B has a higher calculation order than Study A. Again Study A continues to work per usual.
However, Study B is not producing the same outputs of Study A despite having the same calculation precedence and a significantly higher calculation order.
I'm monitoring both studies live and I notice that the values of Study A update with each new event in the market as usual. However, Study B values, of which should be identical to that of Study A because the code is identical, is not updating with each event. The outputs are static almost as if it's updating only at the close of the current bar.
Both Study A and B have UpdateAlways=1 and are using AutoLooping.
Can someone advise as to why this may be happening? Thanks
[2025-11-20 00:49:24]
I've resolved this issue.
