Date/Time: Wed, 25 Nov 2026 21:24:14 +0000
Transaction Log
View Count: 310
[2025-11-18 20:53:25]
User453439 - Posts: 12
Hi
Is it possible to export the transaction log file with Sierra Chart payments into a csv file or similar for accounting purposes?
[2025-11-18 22:09:34]
There is no specific support for this. You would need to copy the information and then get it into a format that you can use as you want.
