Date/Time: Wed, 25 Nov 2026 21:24:10 +0000
Attached Orders setup
View Count: 391
| [2025-11-18 20:16:30] |
| User684034 - Posts: 25 |
Hi ,i'm in trouble to set a type of order . Normally i use a order with target,Stop loss and a Stop; triggered trail stop ! when im in loss i would like to add the same order to the first one and so i will have the same order with the same imputs moving at the same trail ,profit and stop distances . Hope i explained enough well my english is very poor . Thank you very much !!! |
| [2025-11-18 21:51:34] |
We do not understand what the issue is. We find that Google Translate works quite well, so if it is easier to describe the situation in your native language then please do so. We will translate it and post our response in English. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-19 03:54:36] |
Ok John Vorrei sapere come fare per poter aggiungere uno o più ordini, di acquisto o oppure di vendita ad un ordine già inviato ed operativo avente take profit E stop loss con trailing stop, in maniera tale che diventi un unico ordine con le stesse caratteristiche del primo! Grazie |
| [2025-11-19 15:33:11] |
From Google Translate: I would like to know how to add one or more buy or sell orders to an existing order with a take profit and stop loss with a trailing stop, so that it becomes a single order with the same characteristics as the first! Thank you.
In order to add to an existing order and have the attached orders continue to be the same as the original order, use the "Scale In" option. Refer to the following: Attached Orders: Scaling In For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-19 16:22:30] |
Grazie John Per me la lingua inglese è un po' difficile nella terminologia usata in SC. Grazie ancora 👋👋 |
| [2025-11-19 16:47:26] |
We understand. But technology has made it much easier to communicate, which is nice.
