Date/Time: Wed, 25 Nov 2026 21:24:14 +0000
What command is used to continuously adjust screen to the mid.
View Count: 405
| [2025-11-18 16:56:55] |
| User664561 - Posts: 38 |
What command is used to continuously adjust screen to the mid. Thank you |
| [2025-11-18 19:36:38] |
What exactly do you mean by "adjust screen to the mid"?
| [2025-11-19 02:25:59] |
Thanks, I'm wanting the Full Market DOM to adjust to the middle of the screen automatically and continuously.
| [2025-11-19 15:31:13] |
To have the current price always set at the middle of the DOM, so that the bars move up and down rather than the prices, set your Scale to be a "Constant Range" with a Mode of "Recenter to the Last Price on Every Update". Refer to the following: Chart Scale and Scale Adjusting: Constant Range Scale Modes >> Re-Center To The Last Price On Every Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-19 21:28:06] |
Thank you very much, John.
