Date/Time: Wed, 25 Nov 2026 21:24:12 +0000
Volume Distribution Paint Bar Study
View Count: 716
| [2025-11-17 22:28:16] |
| User688525 - Posts: 403 |
Hello Sierra, Is the source code available for the Volume Distribution Paint Bar Study (VolumeDistributionPaintBarStudy)? I am trying to color individual price levels on a bar. Is this the best study to base this off? Is there an ACSIL function, etc., to color price levels based on volume, bid/ask, etc? I am aware of the Bid Ask Volume Bars, but I would like to build a custom study for this. Thank you |
| [2025-11-18 07:12:33] |
| Sierra_Chart Engineering - Posts: 25483 |
Yes the source code is available: SCSFExport scsf_VolumeDistributionPaintBarStudy(SCStudyInterfaceRef sc)
{ SCSubgraphRef Subgraph_Close = sc.Subgraph[0]; SCSubgraphRef Subgraph_BarTop = sc.Subgraph[1]; SCSubgraphRef Subgraph_BarBot = sc.Subgraph[2]; SCSubgraphRef Subgraph_UpperPercentTop = sc.Subgraph[3]; SCSubgraphRef Subgraph_UpperPercentBot = sc.Subgraph[4]; SCSubgraphRef Subgraph_LowerPercentTop = sc.Subgraph[5]; SCSubgraphRef Subgraph_LowerPercentBot = sc.Subgraph[6]; SCSubgraphRef Subgraph_MeanTop = sc.Subgraph[7]; SCSubgraphRef Subgraph_MeanBot = sc.Subgraph[8]; SCSubgraphRef Subgraph_ModeTop = sc.Subgraph[9]; SCSubgraphRef Subgraph_ModeBot = sc.Subgraph[10]; SCInputRef Input_MinRangeInTicks = sc.Input[0]; SCInputRef Input_BottomVolumePercentage = sc.Input[1]; SCInputRef Input_TopVolumePercentage = sc.Input[2]; if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "Volume Distribution Paint Bar Study"; sc.GraphRegion = 0; sc.DisplayStudyInputValues = 0; sc.MaintainVolumeAtPriceData = 1; sc.DrawZeros = 0; sc.AutoLoop = 1; // inputs Input_MinRangeInTicks.Name = "Minimum Range In Ticks:"; Input_MinRangeInTicks.SetInt(1); Input_MinRangeInTicks.SetIntLimits(1, INT_MAX); Input_BottomVolumePercentage.Name = "Bottom Volume Percentage (0-100, 1.0 = 1%)"; Input_BottomVolumePercentage.SetFloat(15.0f); Input_BottomVolumePercentage.SetFloatLimits(0.0f, 100.0f); Input_TopVolumePercentage.Name = "Top Volume Percentage (0-100, 1.0 = 1%)"; Input_TopVolumePercentage.SetFloat(85.0f); Input_BottomVolumePercentage.SetFloatLimits(0.0f, 100.0f); uint32_t OutlineColor = sc.ChartBackgroundColor == COLOR_BLACK ? COLOR_WHITE : COLOR_BLACK; // subgraphs Subgraph_Close.Name = "Close"; Subgraph_Close.DrawStyle = DRAWSTYLE_TRIANGLE_RIGHT_OFFSET_FOR_CANDLESTICK; Subgraph_Close.PrimaryColor = OutlineColor; Subgraph_Close.LineWidth = 5; Subgraph_Close.DrawZeros = 0; Subgraph_BarTop.Name = "Bar High"; Subgraph_BarTop.DrawStyle = DRAWSTYLE_CANDLESTICK_BODY_OPEN; Subgraph_BarTop.PrimaryColor = COLOR_YELLOW; Subgraph_BarTop.LineWidth = 1; Subgraph_BarBot.Name = "Bar Low"; Subgraph_BarBot.DrawStyle = DRAWSTYLE_CANDLESTICK_BODY_CLOSE; Subgraph_BarBot.PrimaryColor = OutlineColor; Subgraph_BarBot.LineWidth = 1; Subgraph_UpperPercentTop.Name = "Top % High"; Subgraph_UpperPercentTop.DrawStyle = DRAWSTYLE_CANDLESTICK_BODY_OPEN; Subgraph_UpperPercentTop.PrimaryColor = COLOR_RED; Subgraph_UpperPercentTop.LineWidth = 1; Subgraph_UpperPercentBot.Name = "Top % Low"; Subgraph_UpperPercentBot.DrawStyle = DRAWSTYLE_CANDLESTICK_BODY_CLOSE; Subgraph_UpperPercentBot.PrimaryColor = OutlineColor; Subgraph_UpperPercentBot.LineWidth = 0; Subgraph_LowerPercentTop.Name = "Bottom % High"; Subgraph_LowerPercentTop.DrawStyle = DRAWSTYLE_CANDLESTICK_BODY_OPEN; Subgraph_LowerPercentTop.PrimaryColor = COLOR_BLUE; Subgraph_LowerPercentTop.LineWidth = 1; Subgraph_LowerPercentBot.Name = "Bottom % Low"; Subgraph_LowerPercentBot.DrawStyle = DRAWSTYLE_CANDLESTICK_BODY_CLOSE; Subgraph_LowerPercentBot.PrimaryColor = OutlineColor; Subgraph_LowerPercentBot.LineWidth = 0; Subgraph_MeanTop.Name = "Mean Top"; Subgraph_MeanTop.DrawStyle = DRAWSTYLE_CANDLESTICK_BODY_OPEN; Subgraph_MeanTop.PrimaryColor = COLOR_GREEN; Subgraph_MeanTop.LineWidth = 1; Subgraph_MeanBot.Name = "Mean Bottom"; Subgraph_MeanBot.DrawStyle = DRAWSTYLE_CANDLESTICK_BODY_CLOSE; Subgraph_MeanBot.PrimaryColor = OutlineColor; Subgraph_MeanBot.LineWidth = 0; Subgraph_ModeTop.Name = "Mode Top"; Subgraph_ModeTop.DrawStyle = DRAWSTYLE_CANDLESTICK_BODY_OPEN; Subgraph_ModeTop.PrimaryColor = COLOR_MAROON; Subgraph_ModeTop.LineWidth = 1; Subgraph_ModeBot.Name = "Mode Bottom"; Subgraph_ModeBot.DrawStyle = DRAWSTYLE_CANDLESTICK_BODY_CLOSE; Subgraph_ModeBot.PrimaryColor = OutlineColor; Subgraph_ModeBot.LineWidth = 0; return; } float MinRange = Input_MinRangeInTicks.GetInt() * sc.TickSize; float HalfMinRange = MinRange / 2.0f; Subgraph_Close[sc.Index] = sc.Close[sc.Index]; Subgraph_BarTop[sc.Index] = sc.High[sc.Index]; Subgraph_BarBot[sc.Index] = sc.Low[sc.Index]; // Calc Volume Weighted Avg of the prices for this bar, find mode, and find range edges unsigned int TotalVolume = static_cast<unsigned int>(sc.Volume[sc.Index]); unsigned int LowVolume = static_cast<unsigned int>(static_cast<float>(TotalVolume) * (Input_BottomVolumePercentage.GetFloat() * 0.01f) ); unsigned int HighVolume = static_cast<unsigned int>(static_cast<float>(TotalVolume) * (Input_TopVolumePercentage.GetFloat() * 0.01f) ); TotalVolume = 0; double Sum = 0; unsigned int MaxVolume = 0; float MaxVolumePrice = 0; const s_VolumeAtPriceV2 *p_VolumeAtPrice = nullptr; int NumVAPElementsAtBarIndex = sc.VolumeAtPriceForBars->GetSizeAtBarIndex(sc.Index); for (int VAPIndex = 0; VAPIndex < NumVAPElementsAtBarIndex; VAPIndex++) { sc.VolumeAtPriceForBars->GetVAPElementAtIndex(sc.Index, VAPIndex, &p_VolumeAtPrice); float Price = p_VolumeAtPrice->PriceInTicks * sc.TickSize; Sum += (Price * p_VolumeAtPrice->Volume); unsigned int PriorTotalVolume = TotalVolume; TotalVolume += p_VolumeAtPrice->Volume; if (PriorTotalVolume < LowVolume && TotalVolume >= LowVolume) { Subgraph_LowerPercentTop[sc.Index] = Price; Subgraph_LowerPercentBot[sc.Index] = sc.Low[sc.Index]; } if (PriorTotalVolume < HighVolume && TotalVolume >= HighVolume) { Subgraph_UpperPercentTop[sc.Index] = sc.High[sc.Index]; Subgraph_UpperPercentBot[sc.Index] = Price; } if (p_VolumeAtPrice->Volume > MaxVolume) { MaxVolume = p_VolumeAtPrice->Volume; MaxVolumePrice = Price; } } double Average = TotalVolume == 0 ? 0 : Sum / TotalVolume; if (Average != 0) { Subgraph_MeanTop[sc.Index] = static_cast<float>(Average + HalfMinRange); Subgraph_MeanBot[sc.Index] = static_cast<float>(Average - HalfMinRange); } if (MaxVolume != 0) { Subgraph_ModeTop[sc.Index] = MaxVolumePrice + HalfMinRange; Subgraph_ModeBot[sc.Index] = MaxVolumePrice - HalfMinRange; } } Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-20 11:50:20] |
Thank you very much Sierra Engineering!
