Date/Time: Wed, 25 Nov 2026 21:06:20 +0000
How Denali data feed and DTC
View Count: 736
| [2025-11-17 20:19:30] |
| User305536 - Posts: 65 |
How can I enable real-time market data subscriptions via DTC for external clients using the Denali feed? I’m not trading via CQG, just reading data.” local machine.
| [2025-11-17 21:40:57] |
| Sierra_Chart Engineering - Posts: 25483 |
You cannot do this. Refer to: Data and Trading Communications (DTC) Protocol Server: Restrictions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-18 16:45:34] |
Well, I was strictly seeking to use it only for myself on same machine! no others, i know that is wrong.. thank you.
