Date/Time: Wed, 25 Nov 2026 21:06:17 +0000
Chart Trade Window - Hot Keys Issue
View Count: 385
| [2025-11-17 18:49:37] |
| Smnitro1 - Posts: 29 |
When I open a chart trade window on my chart, sometimes it doesn't match my trading hot key settings. For example, I have a hot key set to market order with use attached orders checked with simple brackets. Sometimes only place the order without the brackets. Also, sometimes it will change my contract size. Is there a global setting I can use that will be consistent on all my charts and hotkeys?
| [2025-11-17 18:59:49] |
| Sierra_Chart Engineering - Posts: 25483 |
You need to make sure the associated trade window for the chart you are trading from is configured properly. Refer to: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM A keyboard shortcut configured for a Market Order sends a market order through the chart or Trading DOM you are trading from according to the settings of the Trade Window for that chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-17 19:43:32
