Date/Time: Wed, 25 Nov 2026 21:06:19 +0000
Changing the Color and Font size of the Chart List
View Count: 323
| [2025-11-17 17:15:16] |
| User709073 - Posts: 9 |
'Changing the Color and Font size of the Chart List' -------------------------------------------------------------------------------- Gentlemen, There is a 'window' that lists all the various charts that you have created. What I want to do is change the Color and the Font Size of the words/text in this list. I was using Chart |Open Chartbook | Chart | Graph Settings-Chart and with all the different choices in this list, I accidentally used the wrong 'setting.' there are so many choices to choose from, please, I need your help to select the correct one. Thank you. Sincerely, JF |
| [2025-11-17 17:40:14] |
| Sierra_Chart Engineering - Posts: 25483 |
If you are referring to Window >> Windows and Chartbooks, all of that is controlled by the operating system. Not Sierra Chart. Later it will be controllable within Sierra Chart but not now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
