Date/Time: Wed, 25 Nov 2026 21:24:13 +0000
Opening range disappeared
View Count: 325
[2025-11-17 12:37:20]
User577837 - Posts: 8
Good morning. I'm hoping you can help me out. The attached pic shows and opening range study I have on one of my charts. This Study, which is compromised of five studies has disappeared from all my charts for the exception of one. I also had a look back period in which I could look back four days on any chart to see this opening range study. This function is now not showing on all charts. In looking at each chart, it does look like all my perimeters of the studies are entered correctly so I'm not sure why they are now not showing. Appreciate your help!
Private File
[2025-11-18 18:25:09]
We can not say why you would be having an issue. It sounds like something changed with your charts, so you would need to figure out what changed and why. We do not know.
Check if a study is hidden, or removed, or the subgraphs set to display differently, among other possible issues.
If you want to restore a backup of the chartbook to try and recover the studies as they were previously, then refer to the following:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
