Date/Time: Wed, 25 Nov 2026 21:24:17 +0000
Number Bars Calculated Values Alert
View Count: 392
| [2025-11-15 15:09:20] |
| ACW1988 - Posts: 10 |
Is it possible to make an audible alert for AskV - BidV % > 5.0% AskV - BidV % < -5.0% This would be for a standard intraday chart, with number bars set at 30 min intervals. Thanks! always appreciate the help. |
| [2025-11-15 19:12:53] |
| Sierra_Chart Engineering - Posts: 25483 |
Exactly how is the percentage calculated? The difference between Ask Volume and Bid Volume will not give a percentage.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-15 19:13:56
| [2025-11-18 17:10:06] |
And are you wanting this for the entire bar, or per price level?
| [2025-11-18 20:40:00] |
John yes thanks for responding, yes it would be per bar. I tried to re-read some older threads and I see some other traders tried similar alerts, but it was difficult because of the way the data is actually calculated vs the time length of specific bars.
| [2025-11-18 22:08:29] |
And what is the percentage a percentage of? You are wanting the difference of the Ask Volume and the Bid Volume but then comparing that to 5%. 5% of what? Or, if you prefer, what is the "Ask Volume - Bid Volume" a Percentage of? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
