Date/Time: Wed, 25 Nov 2026 21:06:23 +0000
[Programming Help] - Custom Study: Apply changes twice causes unexpected/undesired outcomes
View Count: 363
| [2025-11-15 03:22:09] |
| DirtyGoats - Posts: 7 |
Good day and thank you for your time in advance. Wasn't sure how to properly title this, but I have a custom study that I'm toying around with that draws rectangles from a candle and extends it right. When I apply the study...click "ok" while in the Study Settings menu...click "OK" in the Chart Studies window the chart will perform its "Calculating Study..." and things work perfectly. HOWEVER, if I go into the study a second time and make an input change and click "OK" in the study settings menu I'll get certain rectangles that will also extend all the way left...while also extending to the right. It doesn't impact all rectangles though. so i'm not sure what's really happening or how to resolve. What part of my code would need to be shared to help troubleshoot? Or is there something i might simply be missing that needs to be added? |
| Attachment Deleted. |
| [2025-11-15 20:58:20] |
| Sierra_Chart Engineering - Posts: 25483 |
This really is impossible for us to know what the problem is. Are those rectangles being drawn with drawing tools?: Using Drawing Tools From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
