Date/Time: Wed, 25 Nov 2026 21:06:23 +0000
Trade different symbol on trading window
View Count: 616
[2025-11-14 16:41:10]
User203631 - Posts: 27
my chartbook consist of an ES chart, DOM, and footprint, i like to use ES order flow over MES. Is there a way to have my ES chartbook setup but change the symbol to MES on the trading window?
[2025-11-14 19:08:24]
Yes. Refer to:
Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu)
[2025-11-17 00:03:49]
I've attached an image of my chart settings, doesn't seem to work with how i wanted it. I wanted ES charts and an MES trading window on that chart, whenever i place a trade on my ES chartbook it submits two orders one for ES and one MES.
Date Time Of Last Edit: 2025-11-17 00:22:00
imageES.png / V - Attached On 2025-11-17 00:03:19 UTC - Size: 17.37 KB - 188 views
imageES2.png / V - Attached On 2025-11-17 00:03:22 UTC - Size: 24.06 KB - 115 views
[2025-11-17 00:19:56]
Not possible:
whenever i place a trade on my ES chartbook it submits tow orders one for ES and one MES.
How are you determining this?
[2025-11-17 00:23:27]
I have two chartbooks, one for MES and ES. when i had the settings on the image above on my ES chart and i entered a trade on my ES chartbook, i switched to MES chartbook and it had the same order executed.
[2025-11-17 06:27:17]
There is not a problem here. On the ES chart, since the trade symbol is MES, then you are seeing the orders for MES displayed on the chart. And on the MES specific chart, you are seeing that very same order.
[2025-11-17 13:28:55]
Ok, sounds good. So am I able to have my ES chart book with an attached MES trading window or is it not possible?
[2025-11-17 15:57:04]
You can do this by using this setting in the ES chart:
Set to the MES symbol. The Trade Window for that chart will be for MES.
Date Time Of Last Edit: 2025-11-17 15:59:19
