Date/Time: Wed, 25 Nov 2026 21:24:13 +0000
chartbook
View Count: 369
| [2025-11-14 16:20:20] |
| User220939 - Posts: 65 |
Hi, I create chartbooks and I would like to be able to have traders try them for 1 week. I would like traders to send me their Sierra ID in order to activate them on their account. However, I don't know how to set this up. Can you give me the method? |
| [2025-11-14 19:07:42] |
| Sierra_Chart Engineering - Posts: 25483 |
There is no support for this. There is no way to protect a Chartbook in this way.
| [2025-11-19 10:15:27] |
Sorry, I think my explanation was not good. The customer gives me his Sierra Chart ID and I install the chartbook on his PC. This has already been done for me for an indicator. |
| [2025-11-19 15:43:47] |
You can use our file distribution system to do this, just like you do with a study. But, there are no controls for a chartbook once you send it to someone like there are with custom studies. So once you send a chartbook to someone, they can do whatever they want for as long as they want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
