Date/Time: Wed, 25 Nov 2026 21:06:19 +0000
Trade DOM Recent Bid Volume Background Does not change color
View Count: 381
| [2025-11-13 20:21:03] |
| User303857 - Posts: 201 |
Hello Support, can not change the color of the background on the DOM Unable to change the background color on the DOM for: Trade DOM Recent Bid Volume Background I can change the background color for: Trade DOM Recent ASK Volume Background Thanks |
| [2025-11-13 20:26:20] |
| John - SC Support - Posts: 48659 |
We are not seeing any issues with the "Trade DOM Recent Bid Volume Background" or the "Trade DOM Recent Ask Volume Background". Keep in mind that for both of thse, there is an "Enable" option. You have to click to put a checkmark next to "Enable" in order for this coloring to be used. Our best guess is that you do not have the Enable option enabled for the "Trade DOM Recent Bid Volume Background", but you do for the "Trade DOM Recent Ask Volume Background". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-13 20:29:23] |
That was it exactly !!!
