Date/Time: Wed, 25 Nov 2026 21:06:22 +0000
Hide chart
View Count: 346
| [2025-11-13 18:40:55] |
| User931951 - Posts: 79 |
Hi, I'm having a problem. I can't find a chart anymore. I had enabled the detach window feature, but when I re-enabled the attach window, the chart disappeared, and I don't know where it went. Any suggestions? Thanks.
| [2025-11-13 19:41:40] |
| John - SC Support - Posts: 48659 |
Sometimes when you attach a chart back, it will initially be in a "hidden" state. Select the "CW" menu at the top and select the chart you want, and it will then show up in the main window.
