Date/Time: Wed, 25 Nov 2026 21:06:14 +0000
QuoteBoard
View Count: 414
| [2025-11-13 05:58:43] |
| User841161 - Posts: 357 |
Is there a way to tie a saved QuoteBoard to a Control Board Key, maybe similar to the way you can a certain chartbook?
| [2025-11-13 16:14:45] |
| John - SC Support - Posts: 48659 |
Do you mean to call up a certain Quote Board? Or something else? Apart from "New Quote Board" and "New Quote Spreadsheet" there aren't any Control Bar Buttons or Keyboard Shortcuts specific to the Quote Board. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-13 18:44:59] |
Yes, to call up an existing saved Quote Board-so to easily open and hide Quote Board with click of a control bar button or key.
| [2025-11-13 19:42:42] |
There is not a way to do this. We have noted this as a Feature Request. We can not say when we would get to any particular item. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
