Date/Time: Wed, 25 Nov 2026 21:06:13 +0000
RTH open level is not properly shown
View Count: 364
| [2025-11-12 22:23:39] |
| User051796 - Posts: 2 |
I’m using a 1-minute time-based RTH session chart with Heikin-Ashi HLC, but I’m having an issue I can’t seem to resolve. Each opening bar starts from the previous day’s close, as if the “gap fill” function is automatically enabled even though it’s not checked. Is there a way to fix this? |
| [2025-11-12 22:24:39] |
| John - SC Support - Posts: 48659 |
A Heikin-Ashi chart has the Open of a bar be the average of the Open and Close of the previous bar. So it will always line up in this manner. Refer to the following: Heikin-Ashi For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
