Date/Time: Wed, 25 Nov 2026 21:06:24 +0000
directional movement oscillator study showing NaN ?
View Count: 351
| [2025-11-12 18:39:14] |
| User771976 - Posts: 28 |
This has happened before, but always repaired itself on reboot, etc. I will upload window as per protocol for your review. You will see the same study on the right hand side chart of main window and it is working properly. Need some direction on this one. https://www.sierrachart.com/image.php?Image=1762972559361.png Thanks in advance. |
| [2025-11-12 19:25:08] |
| John - SC Support - Posts: 48659 |
Typically, when you see a "NaN" in the scale, all you need to do is reset the scales. Refer to the following: Chart Scale and Scale Adjusting: Resetting the Scale Let us know if this does not resolve it for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
