Date/Time: Wed, 25 Nov 2026 21:06:10 +0000
MP setup
View Count: 309
[2025-11-12 17:20:28]
paolopens - Posts: 23
How can i set this market profile fixed? i split and organize it and i want it to be fixed when i close sierra charts it went back to normal. i want it to be fixed and when i take split profiles and organize it and save.
[2025-11-12 17:21:31]
John - SC Support - Posts: 48659
A TPO chart will save with any splits and merges as they were at the time the chart was saved. Most likely, if you are not having this occur, then you are not saving your chartbook prior to exiting from Sierra Chart. Be sure to save the chartbook with the chart as you want it.
