Date/Time: Wed, 25 Nov 2026 21:06:20 +0000
Different colors for Market Profile - Market dependant
View Count: 527
[2025-11-12 16:04:54]
User547290 - Posts: 89
Would like to know if there is any way to change the color for the different periods on market profile, based on each period.
Ex: I would like to color the Cash session one color , the Initial Balance another color and then the Over Night another color.
I currently have two colors, 1 - Cash, 2 - OVN. Would like to color each period, but there are only 18 different color selections if I remember
and for a TPO having 30 min. time frames, would like to not have the colors repeat during a 23 hour market.
Any help would be appreciated.
imageSierraChart_64_1QVOk60lRK.png / V - Attached On 2025-11-12 16:04:03 UTC - Size: 109.62 KB - 228 views
[2025-11-12 16:47:48]
John - SC Support - Posts: 48659
Refer to the following Input:
Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Colors
In order to get 3 separate sessions, you would need to use the "Custom Intraday Sessions" and set it to 3 and then setup your times appropriately. Refer to the following:
Time Price Opportunity (TPO) Profile Charts: Number of Custom Intraday Sessions
You can then set the colors as you need.
Note that in a recent release the number of colors was changed to 24. So you may want to update to get this change. To update follow these instructions:
