Date/Time: Wed, 25 Nov 2026 21:06:19 +0000
Data Delay
View Count: 381
[2025-11-12 15:56:09]
Wernitschanton - Posts: 38
Hey Team.
I´m experiencing a Data delay of about 3sec through Rithmic and Teton.
I´ve tried everything mentioned in the documentation, none of which worked.
I do have a fiber connection and my ping seems normal.
And i´m using the Data Delay funtionality in the chart header.
Best
Tony
[2025-11-12 16:39:30]
John - SC Support - Posts: 48659
A delay of 3 seconds would mean that your computer clock is different from the exchange by 3 seconds. It would not be anything to worry about.
To synchronize your computer clock, you can use the NTP (Network Time Protocol) option within Sierra Chart. Refer to the following:
Network Time Protocol Client
