Date/Time: Wed, 25 Nov 2026 21:06:22 +0000
Right-click "hide level" tool function stops working on retracements
View Count: 341
| [2025-11-12 15:16:16] |
| hexpheen - Posts: 15 |
Hi Support, I have an issue where the right-click "hide level" tool function stops working in chart retracements. Other charts in the chartbook this function still works. Also in the chart where the right-click function stops working, I can still go into drawing properties and hide that level - just the quicker right-click options stops working. If I erase the whole drawing and make a new one the right-click function still does not work. It also stops working on previous drawings within the chart. This seems to be related to drawing a "time expansion" in the same chart. I noticed the "hide level" right-click menu function is disabled (greyed-out) for that drawing. In another chart, in the same chartbook, that had no time expansions drawn but had retracements - I tested this function by confirming the "hide level" right-click menu working on the retracement, then drew a time expansion, then tried the "hide level" right-click menu function on the retracement again and it stopped working. Appreciate your help fixing this "hide level" right-click menu function on retracements where a time expansion is within the same chart. I also would appreciate, if possible, enabling the "hide level" function on time expansion drawings (so I do not have to go into drawing properties each time). |
| [2025-11-13 18:06:45] |
| Sierra_Chart Engineering - Posts: 25483 |
We will look into this.
