Date/Time: Wed, 25 Nov 2026 21:06:20 +0000
[User Discussion] - Unable to install current version
View Count: 426
| [2025-11-12 15:10:18] |
| User783032 - Posts: 20 |
I am unable to install current version. An error is being reported during install. Data is now missing ending in September. I am unable to use the version I was running yesterday. This occurred upon start-up this morning. I have sent the install log
| [2025-11-12 16:36:34] |
| John - SC Support - Posts: 48659 |
The error in your Installation Log is the following: Error: File error: Windows error code 112: There is not enough space on the disk.
Since you do not have enough space on your drive, there will be all kinds of issues with Sierra Chart not being able to display the proper information. You need to clear out some space on your drive. For the Sierra Chart data, refer to the following: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
